Help with writing script
Hello,
I am trying to change the script within the (click) mute button on the alarm banner,
I have created a module that resides in AREA_A and I'm trying to write to the module every time the mute button is pressed, thus logging the event.
I need help with exactly what to write, I currently have the following in the script but it is not working,
Private Sub SilenceHorn_Click()
WriteValue strSILENCEHORNVal, "AREA_A/" & strWSName & "ALM_BELT/SILENCEHORN.F_CV",1
The input parameter I'm trying to write to is AREA_A/ALM_BELT/SILENCEHORN
Thanks for any help
  • The out of the box alarm banner on my system has the script below to silence the horn and I have added the logic in red to write a "1" to a SILENCEHORN parameter in a module named ALM_BELT. As long as this ALM_BELT module is downloaded, setup data has been downloaded on all the nodes and the parameter SILENCEHORN has the "Control" security key assigned, this should work.
    Private Sub bmpAckHorn_Click()
      On Error GoTo ErrorHandler
      frsCommonTasks "HornSilence"
      frsWriteValue "1", "DVSYS.ALM_BELT/SILENCEHORN.F_CV"
      Exit Sub
    ErrorHandler:
      frsHandleError
    End Sub
    If this doesn't work and you get an error, check that the area is assigned to that node and the user has the proper parameter security locks for the SILENCEHORN parameter (may have to logoff and back in if security was changed and downloaded).
