5480 subscribers
Dave Grubwieser
17 May 2023 4:54 PM
Elwin Gansekoele
16 May 2023 12:16 PM
Robin
16 May 2023 12:53 AM
10 May 2023 1:36 PM
EvertZwarts
8 May 2023 10:09 PM
4wire in anlog 16 channel
hi
best regards.
dave_marshall
24 May 2016 7:00 PM
Hi Smith,
Dave
Klaus Erni
25 May 2016 6:33 AM
dave_marshall
Hi Smith and Dave,
here is a link to the PDS:
please have a look,
hope this helps,
bets regards,
Klaus
