5480 subscribers
CalebJHolland
9 Nov 2023 7:04 PM
BrianWood
2 Nov 2023 5:37 PM
dolatrec
1 Nov 2023 5:06 PM
Time In Sync Status is False (DV Diagnostics for CIOC)
Simon Ahr
1 Nov 2023 11:57 AM
Rishi
26 Oct 2023 11:02 PM
EIOC periodically sends test messages on the secondary network to check the viability of the secondary network
4wire in anlog 16 channel
hi
best regards.
dave_marshall
24 May 2016 7:00 PM
Hi Smith,
Dave
Klaus Erni
25 May 2016 6:33 AM
dave_marshall
Hi Smith and Dave,
here is a link to the PDS:
please have a look,
hope this helps,
bets regards,
Klaus
