5479 subscribers
25 Sep 2024 12:01 PM
Weu Butakep
24 Sep 2024 1:24 PM
John Rezabek
20 Sep 2024 1:47 PM
John Rezabek
19 Sep 2024 9:01 PM
Valentin Borsu
17 Sep 2024 2:01 PM
PK Controller Ethernet I/O Port Download Behaviour
4wire in anlog 16 channel
hi
best regards.
dave_marshall
24 May 2016 7:00 PM
Hi Smith,
Dave
Klaus Erni
25 May 2016 6:33 AM
dave_marshall
Hi Smith and Dave,
here is a link to the PDS:
please have a look,
hope this helps,
bets regards,
Klaus
