CTLS Low Select
Question: How does the  CTLS block Limits the output of the non selected PID block ?  It seems like the output of the non selected PID block is somehow fixed by the BKCALC of the selector block.
Status:
  • I have  a very simple low select CTLS which selects between a PIC and a FIC.
  •  Output value of the my FIC is %16 and the PC is %47.
  • Output of my CTLS block is of course %16
  • %16 is entering the BKCALC of my PC and FC
What I want to know:
  • Although the Setpoint of my PC is 2000 and the current PV is at 1500, the output of the PC is not ramping up towards %100.  It seems like it somehow has been fixed to 47.  it moves very slightly but I expected to move a lot faster.  Does it have anything to do with the CTLS affecting the PC block?  I don't see any tracking logic on the PC. The Action and Gain of my PC is correct.
Learner
  • Learner,
    Matt
  • Former Member
    Former Member
    In reply to Matt Stoner:
    Learner,
    Regards
    Col
  • In reply to Former Member:
