5482 subscribers
KoBriZo
14 May 2021 3:20 PM
FMT File for motor module
richardwilliambrooks
13 May 2021 2:57 AM
What is the simplest way to obtain a list of all supressed alarms that are active?
Senthilkrishnan M
11 May 2021 7:15 PM
Will Use of Floating array parameter increase the execution time and load the module
DCS Newbie
11 May 2021 6:30 PM
Changes to Detail Faceplate
11 May 2021 10:22 AM
Unable to get Program to output to file when using DeltaV Live Open Application function
Basic Functional Safety Question
Batch Exec failed to verify due to transition rather than termination in an operation. Possible impact?
Question about OPC Licensing
Question about LS AI CHARMS
About self-regulating and integrating questions
A rather basic question about DCS
Hello All,
Hello All! I am applying for a Process Control Specialist job with a company dealing with Emerson products and I was wondering if you could help me answer one question on the online application form. The question is, " Describe the key elements of an overall DCS architecture"? I did some research and found a lot of information but I am not sure detailed the answer should be since this appears to me as a very broad question. Since you are the experts, I thought I will ask for your help!
Thank You!
Azmil ( Maskara )
