VIM2 card cables
Hi Everyone,
I could not find any indication in BOL about the proper ethernet cables to use with an S-series VIM2 card.
I see that the two sockets on the card are different: the redundancy link is plastic and the VIMNet is metal.
So, what kind of Ethernet cable to use for the VIMNet? Like in the case of controllers, one end of the cable should have a metal connector, the other one not? Should we use CAT5 cables?
Thank you,
Istvan
  • The redundancy link is a special cable that should be sent from either your local Emerson support or from Mynah Technologies.  The link only works if you have the newest firmware revision installed on the VIMs.
    The Ethernet cable is just a standard Ethernet patch cable set to the length from your VIM to your destination network.
    Thank You,
    Joshua Wooten
    Network Engineer |PLC & DCS Controls Programmer
    Microsoft Certified Systems Administrator (MCSA)
    M&G Polymers USA, LLC | SR 2 Apple Grove, WV | 25502
    Office: 304-576-4553
    Mobile: 304-360-6051
    Sent: Thursday, September 05, 2013 5:53 AM
    To: [email protected]
    Subject: [EE365 DeltaV Track] VIM2 card cables
    Hi Everyone,
    Thank you,
    Istvan
  • In reply to jwooten84:
    Thanks Joshua, but this did not answer my question. Usually Emerson gives recommendations like:
    Controller-to-switch: The shield on the controller’s RJ45 connector connects only to a Faraday cage in the controller; not to the controller’s DC ground. Therefore, the RJ45 connectors are floating and the single point of ground is made at the switch to which the controller is connected. Build this cable assembly with a shielded, metal-enclosed RJ45 connector on both ends.
    Workstation-to-switch: To prevent ground loops, build this cable assembly with a shielded, metal-enclosed RJ45 connector on one end and an isolated, plastic-enclosed RJ45 connector on the other end. The metal connector end of this cable assembly/link must be placed on the switch and not on the PC.
    So my question would be: on which end of the Ethernet cable should we have metal-enclosed RJ45 connectors for the VIMNet connection? On both ends? Or should one of them be simple plastic?
    FYI, we are not using VIM redundancy.
    Thank you,
    Istvan
  • I am not the electrician that made/installed the cable, but I believe ours are unshielded cable, plastic connectors on both ends.  We are connecting to Stratix switches for PLC communications.  Have several VIMs and PLCs that we are communicating with.
    Thank You,
    Joshua Wooten
    Sent: Thursday, September 05, 2013 9:34 AM
    Subject: RE: [EE365 DeltaV Track] VIM2 card cables
    Thank you,
    Istvan
    Istvan,
    I am an Application Engineer at MYNAH Technologies and I published an article on this topic.  The shielding rules for the VIMs are exactly the same as for the DeltaV Controllers because the two are based off of the same internal design.  The RJ45 shield grounds the VIM's Faraday cage at the switch so shielded connectors should be used on both ends.
    www.mynah.com/.../virtual-io-module-network-cable-shielding-and-grounding
    István,
    I think the information you're looking for is in the Mynah Knowledge base. Take a look at the following link:
    This doesn't talk about the Redundancy link cable, however, I believe the cable you get for the VIM redundancy link is unshelieded.
    Feel free to give Mynah a call if you have anymore questions, they have great support and can answer your questions right away!
    http://www.mynah.com/support or +1.636.728.2000
