Size limitation for DeltaV Operate FDS file (Dynamo Set)
Is theer any size limitation for Fds file (Dynamo Set in deltav operate)? I was adding some modules in FDS where it prompted for Memory Violation.
  • I've never run across a size limit but I think everyone who works with DeltaV Operate has come across Memory Violations in Configure mode.  It was probably just a coincidence that you were working with the FDS file at the time.  Did you restart Operate and try the same thing again?
  • I was trying to import forms and VB Modules in FDS file (In DeltaV Operate VB Window). When i imported manually it was prompted for the error. When i did it through script it was same observation. I was trying to import around 80 forms. Then I splitted them in groups there by I succedded to import whole forms. This qt'n was raised to confirm if anyone has tried this or faced similar issue.
    Thanks for the comment.
