I have been having some trouble with the replacement of a Foundation Fieldbus 3900 SAAB Radar tank level indicator with one currently operation in the field, but showing sporadic failures being the reason for the replacement. Following the Replace procedure, it was successful up until the commission step. The Fieldbus Device Replacement Wizard window showed ‘Step Started: Commission the new device. Step Stopped: Commission the new device’. The only option to proceed or get out of being stuck is to Cancel. The old device was able to successfully Decommission, while the new device was showing under Decommissioned Fieldbus Devices.
DETAILS:
Steps I followed:
Does anyone have any thoughts? It closely aligns with DD mismatches and parameter misalignment from refurbishment, even though the device shows correct Device Type and Revision as the rest of the devices are configured for. So that is my next step is to validate the radars settings via TREX, but until then, I’m at a loss.
Riley
