Dear All
I've deltav system with 2 redundant DCS series M controller and other two pairs for ESD , 6 ows, 2 ews, one Pro plus version 14.31 lts
On diagnostic DCS ctrl Keeps giving yellow alarm that redundant fail /not available as shown below.
Then everything goes well for 3 to 5 min then gives the same error again also for 3 to 5 min .
I've removed one ctrl the system runs smoothly by the other .( do not matter you remove active or standby)
Then returned it back , after synchronizing the error is repeated again.
This issue is in DCS ctrl only
note some I/o channels are open and other give error but should not disturb REDUANDANT CTRL PAIR
Also in some place it shows IO error in the standby controller
please advise
Thanks
In reply to Andre Dicaire:
In reply to hagouda:
