DeltaV System running V13.3.1
The SV of a HART signal will intermittently drop down to zero then come back up to normal reading. The primary variable that uses the hart_field_val remains a constant reading. The control module is set up as a PCSD Analogue Input Module V13.0.0
Diagnostics value shows GOOD for Overall Integrity.
CalebHolland
