Hello all, apologies for the direct technical support ask here, but I've dug into this one pretty deep and am totally at a loss.
About a month ago, we had a valve (PCSD V5.2) generate a "WA_ALM" with the Alarm message "SP Write Error : REQ SP Failure". This caused the parent EM to receive the failure, and therefore hold the phase and ultimately vent our tank.
Now, digging into this, the perplexing part is that in order to get this specific alarm, DC_CTRL/SP1/OUT2 would need to have a value of 1.
Not to get too lost in the details (though I'm happy to if anybody wants more information), OUT2 is an internal parameter to this calc block, so it cannot be overwritten from external logic. And within the calc expression, there are 8 lines of code that could possibly set OUT2 to a value of 1. But meticulously going through the execution line-by-line, there is always some condition that would explicitly prevent those lines from executing in the case we observed. Genuinely, it appears impossible that we could have seen this alarm, and yet - we did.
Has anybody seen anything like this, whether related to to this specific error, or otherwise a situation where a parameter was set to a transient, seemingly impossible value?
A couple pictures below. Again, apologies for the long-winded message but I'm running out of leads.
(If anyone from Emerson sees this, GC-2505-6946)
First OUT2 being an internal variable can't be updated is not entirely correct, at the beginning of the execution of the CALC block it copies the current values of INs and OUTs parameter to the internal variables. So this means another block could update the OUTx parameter and the next execution of that calc block the internal variable will be update to what value. Now I don't think another block is doing this...
REQ SP Failure is generated when logic has written to the REQ_SP parameter and it's not a valid SP which are (note: this is from memory of the logic and there might be more or slightly different than I recall):
I tried to look up the call but didn't find that call number, is there a typo?
In reply to Matt Stoner:
Hey Matt, thanks for the response.
You're correct - the variables are loaded in, but the first line of the calc block logic sets
OUT2 := 0;
So we always know we're starting from a known value every scan.
For interlocks and permissives, we have no permissives configured on this particular block. There are two interlock conditions, neither of which was active at the time of the event.
Additionally, the valve mode remained in CAS throughout the duration of the event - which is important, as we're using Force SPs heavily here to manipulate this block valve based on a PID controller output. And on that note we were able to replicate a Force SP error, but that is distinct from the "REQ SP Failure" we saw here.
There are a number of other expressions that set OUT2 in the DC_CTRL block. A handful can only set the value to multiples of 2, or 5: never 1.
And then there are a few which rely on a parameter called 'REQ_SP_TRK', which in our case as far as I can tell is set statically to 'TRUE', and causes the remaining lines to skip execution.
In the GC ticket there is a PDF I prepared that goes into more detail - and it appears to still be open when viewed in Guradian (screenshot below).
In reply to Michael Guynn:
